7v quick check
8 Jun 2004
Sarrrf London
Hi guys, just done a 7v mod on a 3 pin to 4 pin molex adapter, can you confirm this is correct before i power up? I'm not convinced it is!
damn, can't get a decent shot of it :|
To explain the layout, its Molex 1 (connects direct to PSU) ---- Molex 2 (extender, daisy chain molex) and off of molex 1 is 3 pin fan adapter.
SO,
Molex 1 (to psu) is
black (+black fan wire)
black
Red
Yellow
Connects straight to Molex 2, which is
Red
Black (wire which at one end has fan black wire, but not this end)
black
yellow
I know that's a head screw, but does anyone get what I mean? I've looked at numerous sites, but some have the red completely moved (at both ends) some don't. I don't wanna blow the psu!
I'll get a picture of mine now mate.
I've just done one and it's working. :)
P.S- Do you have one of those Y adaptor things?
EDIT: Here's the guide I followed. Link
If you get stuck with that give me a shout and I'll get a photo of mine. :)
Awesome mate, cheers! Its not a Y adapter as such, its a 3 pin to 4 pin adapter with the usual extra 4 pin attached too to let you daisy chain devices.
Just got a photo of it. Sorry about the quality. (Phone pic)
That's how I've done it. The one with the Molex>3pin is the 7V one and the other one is the 5V one. :)
cheers! So the one to the upper right is the 7v?
It looks like an unchanged molex though? yellow + fan cable at top, then black and fan cable directly below. Isn't that unchanged?
Just labeled the diagram for you. The bit with the red boxy-thing round it is the thing that changes the 3pin fan adapter to the molex one.
  • Fan connector.
  • 7V Molex.
  • 5V Molex
Thanks for that, really appreciate it.
How do I get the female pins out?! Sorry to sound like a noob :( The male ones push out, but i can't switch the cables at the female end :(
I just put a small screw driver in the hole and pushed the little pin things flush with the rest of the metal connector.
A light helps quite a bit.
