Are you actually playing any games where 10-bit colour depth is supported? If not you won’t see any benefit anyway. I suspect even if you were you’d probably find the extra fluidity and better motion clarity of the higher refresh rate better than anything you might see from the better bit depth, if you could spot any real difference with the colour depth that is at all
