Hi there,
Just testing out a recent 8Pack build I received and noticed that benchmarking with CPU-Z doesn't seem to bench as high as expected - any ideas ?
All settings as I received them - all cores overclocked at 4.2Ghz.
As you can see I get varried results each time I run the bench against the reference CPU. Should this not be scoring more consistently better than given same chip reference numbers considering this is overclocked - or is this normal?
https://www.dropbox.com/s/4xys0jo7j2p6y8g/7900X at 4.2Ghz.JPG?dl=0
Intel i9-7900X
ASUS ROG Strix X299-E
Corsair Dominator Platinum 32GB (4x8GB) DDR4 PC4-25600C16 3200MHz
EK Water Blocks Predator 240 All In One Watercooling
All bios settings as I received them - all cores overclocked at 4.2Ghz. What Bios settings should I be posting here for help and is there an easy way to extract them for posting?
Thank you
Intel i9-7900X
Thank you
