ok heres where im at and getting p''''ed off recent rebuild/upgrade as sig.
my pc will shut down and restart after playing an hour or 2 in arma 2 arrowhead.
i had the 290x oc so i set to default same problem
4.4oc stable removed and tested using 160 bclk passed all occt tests cpu/linpak/gpu/power supply also passed unique heaven realbench both tests.
definitely not an oc issue or heat issue.
after the restarts there is no bsod in event viewer its a error 41 kernel power issue.no error in chk disc windows memory check.
upon rebuild filling wc loop i must have damaged power supply as the on/off switch no longer works ??? ax 1200w about 1 yr old seems to still work and passes all stress tests.
im leaning towards its the power supply but it passes all the vigorous stress tests, far more stress than playing arma 2
[/URL][/IMG]
