8 pack ram booting issue
18 May 2010
London
So had my 8 pack 32Gb cl14 3600Mhz maybe 2 years and ran it with no issues.
Run it at docp no issues.
However last 3 days now in a row pc is failing to boot with the the docp settings applied.
I thought it might be the -15 co on the CPU but having removed that but kept the docp on the ram I just tried to turn it on and it again fails to boot from cold and resets the bios.
Any idea what I can do to try and stabilise it?
I'd suggest running a memory test on it at the default settings.
You mean without the docp profile applied?
That's the thing with the docp on and -15 on the cpu I can game for hours no instability. It's just cold boot that no longer works.
Maybe I give the ram more voltage...
OK, I think it was just a bios battery issue.
I changed the battery turned off the pc for 15 mins and then started it again and this time it booted with the DOCP profile applied.
I'll find out tomorrow again when I start it up if that truly solves it.
