8 pack systems
Not yet. However, if you want one with an updated spec we've nearly finished the preparation so we can build one for you.
Like Scott says the binning and design is done so X99, 4 980 Supernova is available should you want it. The wait was on EK watercooling RVE blocks which we can now order in.
Maybe yes!!! The spec of the new Supernova is a beast.
X99 5960X
R5E
4 x 980 @ 1500mhz
DDR3200
Just for starters!!!
X99 5960X
R5E
4 x 980 @ 1500mhz
DDR3200
Pfft, come back to me when it can run Crysis. :D
Slightly off topic, but does this mean there's a revision of Infinity due as well? Quasar/Pulsar need to move to 980 SLI, hopefully the cheaper models will go back to Nvidia also.
Just out curiosity. How much of a markup are the 8 pack systems? Like how much is someone paying for all the work of putting the system together and all the overclocking done plus the hand picked parts?
Calculate the price of parts, subtract that from the cost and voila!
