- 30 Nov 2010
- UK
Hey, hope you may be able to help me.
I am trying to get my 2500k and Z77X-UD3H board up to 4.4ghz (was a ocuk bundle with 4.4ghz but updated bios and lost the settings) I have tried just upping the multipler with 44 and everything else set to auto including the Vcore, but when running Prime95 within a few minutes i sore the Vcore go up to 1.54 from 1.35 which I know the 2500k shouldn't go past 1.4 so I stopped Prime 95 right away.
I then tried setting the Vcore manually to 1.35v but within seconds of starting Prime 95 it crashes. So I thought I would try doing multipler of 42 with auto Vcore which gave me 1.320v and that runs stable in Prime 95 with temps of around 56c I then tried setting the Vcore maunally to 1.320v to see if that would crash the same as setting the vcore maunally with x44, but again the second I turn Prime 95 on it crashes.
I have tried each time with the memory profile set to XMP Profile 1 and again with it on default. Just incase that had something to do with it.
Any ideas on what I should try next?
System Spec:
z77x-ud3h
2500k
H100i
Corsair HX850
Kinston HyperX Grey Genesis 4GB x 2
System Spec:
z77x-ud3h
2500k
H100i
Corsair HX850
