8 Packs recommendations? (as cpu help as well :D)
20 Nov 2009
Bangor NI
Hey mate I was wondering what you would recommend out of the 780 classified and the lightning? Or should I just go with a cheaper model as it's only going to be on air.
Also I'm having a hard time getting into windows when my clock is 4.7Ghz or more (thread here) http://forums.overclockers.co.uk/showthread.php?t=18554391)
4.6 is without issue at all but I've now gone up to 1.425v in the bios and it won't let me into windows :/ thoughts?
Thanks
Both those 780 are great. Either will serve you well. Standard 780 are not for me at all as these ones offer far better clocking even on Air.
No gain over 4.6 really with that chip in everyday stuff and only one card to feed. I would just leave it as it stands man, or even better upgrade to Haswell!!!
