In my antec 1200 case the 8 pin 12v CPU cable (split into 2 4 pin connections) doesn't reach the socket on my motherboared (p6t deluxe) I bought an extension cable for it but now only 4 pins fit in because the shapes on the left 4 pins don't match with the motherboards socket.
Can you buy different shaped extension cables, e.g. i got the wrong one or can you run the motherboard of just 4 pins?
