I'v always been led to believe that it's required, TBH I've only once powered a system up without it connected and the system did fire up but I also has a normal molex connected to the mobo.
4 pin will fit in the 8 plug on the mobo by the way.
If you got 8 pin then I tend to fit 8 pin.
If your overclocking or running quad then personaly I would install the 8 pin, so least you have got full power to cpu.
