- 13 Jan 2004
- UK
Anyone know if these are out to buy anywhere at all, my PSU supports it but didn't come with the cable which is a pain.
byron_hinson said:Not for overclocking they won't!
Tute said:Hang on though, if they both go to ground, then why does anyone need to bother with this new 8 pin connector? What was wrong with the old 6-pin one?![]()
paradigm said:In the actual specification IIRC one of the two additional pins is a voltage sense or something similar. Drawing it to ground gives a reading that allows CCC overdrive to run. So whilst the actual specification of the new PCIe 8-Pin connector does add a new feature, its superfluous.
It's something to do with the power the board can suck out when under strain (ie. largely overclocked) and apparantly it has a chance (very low, but a chance nevertheless) of melting the wire or causing damage to the card or the wire if the extra connectors aren't used. From reading up on it, people are saying that it's 2 extra ground's, but other places are saying that it's 1x 12vDC and 1x ground, because the wire has 4x yellow cables and 4x black which indicates another 12vDC, instead fo 3 yellow and 5 black which would mean 2 ground.Tute said:So what were they thinking when they designed this new connector? "Lets be as difficult as possible"?
flibby said:It's something to do with the power the board can suck out when under strain (ie. largely overclocked) and apparantly it has a chance (very low, but a chance nevertheless) of melting the wire or causing damage to the card or the wire if the extra connectors aren't used. From reading up on it, people are saying that it's 2 extra ground's, but other places are saying that it's 1x 12vDC and 1x ground, because the wire has 4x yellow cables and 4x black which indicates another 12vDC, instead fo 3 yellow and 5 black which would mean 2 ground.
Which PSU do you have ???byron_hinson said:Anyone know if these are out to buy anywhere at all, my PSU supports it but didn't come with the cable which is a pain.
LoadsaMoney said:You don't need the 8x pin to overclock the 2900, you can overclock it fine with just 2x 6 pins connected, all the 8x pin does is allow you to use the overdrive of the CCC, but just connect 2x 6 pins and use ATi Tool.
Theres no reason to get the 8x pin for the 2900 at all, unless you want the overdrive section of the CCC to show up.![]()
MilanoChris said:Are the new NVIDIA cards 8 pin? If not I recently spend about 120 quid on a PSU that I'll have to replace![]()
paradigm said:Do you ever read a thread you post in? This has already been covered once.
helmutcheese said:Not yet my Superclocked 8800Ultra is 2x 6pins.
MilanoChris said:Thanks for the clarification. I could run two of them then![]()
Oooh if I had the cash for one yet alone two and a monitor to make the cards actually do some hard work![]()
