8 pin to 4 pin 12V conversion ?
19 Oct 2002
Pembrokeshire
I had a problem with my Motherboard on Friday so I picked up a replacement (different make). Just swapped over all the bits and on final stage on rebuild found that the new MB had a 4 pin 12V connector where my old on had an 8 pin.
Problem is the Coolermaster 1000W Modular PSU only came with 8 Pin leads and not 4 pin. What is my best choice ? is there a 8 pin to 4 pin converter ?
Alternatively as I really need the machine working again ASAP is there any way of using my 8 pin connector on the 4 pin ?
Thanks, hope someone can help
Jase
I had the same issue, it's only when I undid my neatly wrapped cables I found that corsair had provided a second cable with a 4 pin plug..
AD
there things can be annoying at times. I had to cut mine up to make it but don't do this unless you know what you are doing!
Now I feel stupid, the PSU in the link Ghost posted was not mine, mine is the modular version. However when I saw the picture it got me think about the cables.. so I dug out the computer and looked in the case again...
When I originally built the machine I didn't have a use for a 4 pin cable so I tucked it in the ridge running along the top of the case out of site... guess what, it was still there, dohh :)
Can't believe I forgot about that, anyway plugged it in, all worked fine.
Cheers guys
Jase
