8 port switch for a LAN party
1 Nov 2005
Essex, UK
Hi all,
Can anyone please recommend a decent yet reasonably priced switch that's fine to use at a LAN party?
There will only be six of us hooked up, so I need more than a 4-ports, which there seem to be an adundance of.
And what about going wireless? Is there a decent 8 port wireless DSL router? I can only seem to find reviews of five year old equipment!
So is it a router you're looking for, or a switch?
Sorry, yes a router.
I've been at work for the last 12 hours and things are starting to get a tad blurry..!
off the 'bay i managed to get a 12 port 10/100 managed switch for £10 delivered just plug something like that into any old router
routers with more than 4 ports arn't exactly common, and if you do manage to find one, there usually pretty expensive
what exactly do you need a router for for a lan party ?
Erm, to connect up 6 PC's with???
I take it I could just get a switch and assign the PC's fixed IP addresses and not use DHCP? I just thought the easiest way to go was to get a router, set all the PC's to auto-assign IP addresses, connect them all up and voila.
Am I missing something?
If you don't need a connection to the internet, you don't need a router. You could install a DHCP server on one of the PCs. Or you could, as suggested, plug a 12-port switch into any old router. The DHCP would still work.
I haven't got a switch or a router, so I thought I'd just get the lot in one box, surely that's less hassle?
Ok, but I doubt you'll find a router with 8 ports. Top grade stuff would probably have 1 port, as it'd be plugged into a switch. Home user stuff usually has 4 ports, because no one really needs anymore.
Well you won't as as already said, the most ports you're going to find on a reasonably priced router are 5, so you'd need atleast one extra port, hence the need for a switch.
What type of connection are you using? a Linksys BEFSR81 has 8 ports, but will need a cable or ADSL modem.
There are two ways I can go with this.
If I just want to use the hub/switch/router for LAN parties, then I'd like just one box that we can all connect to. There'll be at least 5 or 6 of us.
If I want to plug my cable modem into it, then I'd like a wifi DSL router, but one of those with 8 ports that I could also use for LAN parties are few and far between.
If we just say for the time being, I just want something for a LAN party that me and four friends can connect to, that's fairly cheap, what should I get???
tbh, its abit of a waste getting a router if all your goign to use it for is DHCP.
a normal 8 port switch will do you fine and will be a lot cheaper.
if you want to use DHCP you can set it up on one of the computers, otherwise just assign ips manually, its not exactly hard doing that, u dont need to worry about gateway and dns address, etc
I've got an 8 port netgear router myself due to the large amount of computers at this house, cost us over £100 for it. I'd definatly advise going for the switch if you don't need internet.
