8 speed and 16 speed ?
19 Feb 2007
Northampton
SO i know x48 boards are great for crossfire but i have a P45 board and was wondering, just say i get 30fps right now in crysis with everything maxed out, how much more would i get in an x48 mobo with full 16x speed ?
*EDIT* not sure if this is for graphics or mobo section*
At high res, from what I have read it definately makes sense. There are some benchmarks around with the P45 vs the X48. Worth checking out as some of the results are surprising.I could be going mad here ofc.
Tweaktown said:
Final Thoughts
This is really a very interesting article and is something people need to be taking note of. The first thing you need to be checking is if you're reading a review where Crossfire is being tested. Make sure that the board there using is a x16 / x16 motherboard. The results really do speak for themselves and it’s clear that there is a performance difference between a x16 / x16 configuration which the X48 offers, and the x8/x8 one on the P45.
If you’re really thinking about going down the Crossfire path, we would be highly recommending that you spend the extra money to go to an X38 or X48 based motherboard over the P45. Of course, if you’re not then it doesn’t really matter. With one card the P45 runs at x16, which is exactly what you want.
The thing is, the X48-DQ6 is only about 10% more expensive, so you could easily say that you should just spend the extra money and get that. You may in future go Crossfire without knowing it yet, but admittedly the P45-DQ6 does have some very cool features such as the new ICH10R controller, loads of SATA ports and just some really funky new add-ons like the power buttons on board. Of course, we will cover all these in more detail in our full motherboard review at a later date.
Before you rush out and buy that P45 board thinking that x8 / x8 will be just fine, sit back and have a think if you’re really aiming to go down the Crossfire path in the near future.
