What exactly are 8valve engines?
For instance you can get 1.2 8v corsas and 1.2 16v corsas, 16 valves obviously have 4 cylinders, 4 valves per cylinder so I assume 8 valve engines have 2 cylinders, 4 valves per cylinder?
OR
Are 8v engines 4 cylinders with two valves per cylinder as opposed to 4?
Also, on a same chassis car, with a same capacity engine, is it true that 8 valves are generally more torquey than 16 valves and have more power lower down the rev range, and a 16 valve equivalent car will be pretty much the same 0 - 60 etc. but you have to rev the **** off it?
Cheers
OR
Cheers
