Hi, guys
I Recently purchased the Ultima Vanquish System, from Overclockers.
When I run Arma 2 on the machine, the cores go up to 80c after about an hour when using coretemps software as a guide.
The machine's cores Idle at around 62c, and unit is located in a well ventilated area.
I ran a test which told me the fan was running at 60% but I don't know how to make it run at 100%?
Am I in danger of screwing up this new machine?
What are the normal gaming/idle temps?
The full setup is-
Case Coolermaster Elite 335
Intel Core i7 920 D0 3.80GHz!
Gigabyte GA-EX58-UD5 Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
Patriot Viper 6GB (3x2GB) DDR3 PC3-12800 (1600MHz) Low Latency Tri-Channel
Titan TTC-NK85TZ Fenrir CPU Cooler
Graphic Card: Nvid 295 GTX 1792MB
Sound card Creative Sound Blaster Audigy SE 7.1 Sound Card - OEM (30SB057000000)
Seagate Barracuda 7200.12 1TB SATA-II 16MB Cache - OEM
Belkin F5D7000UK 125Mbps Wireless Desktop PCI Network Adapter
LG GH22NS40 22x DVD±RW SATA Dual Layer ReWriter (Black)
Corsair TX 650W ATX SLi Compliant Power Supply
Arctic Silver 5 Thermal Compound professionally hand installed by our technicians
Any advice would be greatfully accepted.
Sorry for my ignorance, but I am sure this cannot be right?
Thanks.
SP
The full setup is-
Thanks.
SP
