Just wondering if 80ºC is a tad hot for a pre built-P4 pc
If the chip uses the sensor to establish whether it needs to throttle, then if the sensor is faulty it will throttle at 80 on the sensor, not the real 80 degrees.Pottsey said:There is a chance your temp sensor is faulty. Mine reports my temp as about 20c higher then it is and its hit 104c+ before.
Load up throttle watch and see if it goes off at 80c. If its not throttling its ok and its your temp sensor that’s wrong. Also your bios should how the temps a little higher then in windows.
Is it a Dell PC? A lot of Dells have a plastic shroud around the heatsink which ducts air to an exhaust fan at the rear of the case.naffa said:Lol, just as I thought. It has a ridiculous fan guard which I'll be removing, I'll be placing an extractor fan on the back and re-seating the CPU in some fresh thermal compound. If the crazilly high temps persist then I'll be back for help from the trusy OcUK Forums.
Dolph said:It's getting very close to thermal throttling levels, so yes, I would definitely say it's too hot.
IIRC a P4 throttles at 85oC
kleox64 said:anything below a prescot will have approx 70C throttle point, regardless of what throttlewatch displays. Remove the HSF and power the machine on, look in the BIOS and your temp should be pretty much 70C.
