i would suggest something more like this, you can overclock the cpu easily, 8gb ram, 1tb storage. you can always nuy an ssd at a later date, i recommend you get windows 7 too.
Is there any reason why you have chosen a Micro ATX mobo?
Also the Corsair A50 comes with thermal compound I believe. Don't know what it is like.
I would choose MX-4 over Artic Silver 5 if you don't use the supplied compund.
