I decided to invest and upgrade the standing cooling in the 800D, so purchased 2 x NF-P14s and 1x NF-P12 for the Corsair A50 cooler.
I've performed two simple and not particularly scientific tests on the following hardware: i7-2600k @ 4.6GHz and ATI 5970.
First off, here's a picture of the fans installed- all of them running at maximum speed.
The test
20 minutes of Prime95 over all cores and furmark burn-in test.
GPU and CPU Idle - Before Upgrade
GPU and CPU Idle - After Upgrade
GPU and CPU Loaded - Before Upgrade
GPU and CPU Loaded - After Upgrade
Conclusion
As you can see very little change in cooling performance over stock. I don't have anyway to measure the noise difference but if I had to guess I'd say it was the same if not slightly louder.
In the picture you'll see I've added a second 140mm fan in the bottom chamber (after I had performed the tests above). I can confirm with my setup this additional fan makes no difference... I've seen people commenting on drops of up to 10c but I simply haven't seen this.
Money well spent
The test
Conclusion
Money well spent
