800D Light leakage?
5 May 2003
UK
Hi guys
Received the awesome 800D today, loving it so far except one issue. I get light leakage from both side panels.
Opinions? It may seem a bit anal but after paying £230 I would have hoped everything would fit flush. It seems as if the panels are bent / ill fitting.
Some black tape would probably hide the "gap" but this wouldn't really be giving a better fit more hiding the issue.
Philly, maybe, I've been playing with the cabling at the rear to see if it helps (it did not) but I get the same thing on the windowed side which obviously has no cables at all against it.
Thanks schizo.
mine seem's to be ok.
mine is under my desk at the moment and cant really see it but i will take it out today and have a look.
Mine did this when I first got it, bit of a gamble but I just left it to see if it would close up over time and it certainly has, although I've had a few config changes since new.
Perhaps they just need running in and a little bit of normal operating heat (! - blasphemy for an OC) to let everything seat properly?
Interesting! :)
Are you guys using cathodes? To be fair, if I didn't have white cathodes in this would probably be harder to spot.
