So I want to add another radiator to the bottom compartment of my 800D, I cba to Mod it to fit a 240 in there so I need to know if I can fit a 140 in there or would it be better to stick with a 120?
Corsair's site says a 140mm does fit there but if you have a 120 you might as well use that. I prefer 120's because there is a larger choice of fan's anyway.
