800d questions:
2 Dec 2009
Hi all.
Just recieved my corsair obsidian.
I transferred my rig over earlier tonight, but theres a few things troubling me.
My Dvd drive looks grey compared to the dark black, it there any brands which may look more fitting with the 800d?.
The top of the case looks designed for some W?C radiator, however on my air cooled setup it looks like its going to be a dust trap, is there anything that could fill the void?
Also, which header do i hook the ac'97 plug upto? its attached to the HDaudio cable, is it just a choice?
regards
Callum
cheers ace!. is that not just a reader though?.. so i would still need something if i wanted to write?.. possibly externals the easiest answer.
Lian Li black drive covers, a dremel, some "no more nails" double sided tape and about an hours work...
Nick
