gorrrrgeous
I like the implementation of the thin 120mm Rad too.. very good, might have to nab that idea from you when I rebuild my loop
Once you have finished could you add a picture with the side panel on?
That would be great, thanks!
Keep up the good work!
P.S. are those corsair fans any good? Im thinking of getting one to go under the grill where the 2 WC tubing grommits are (by the PSU).
On the drain I also needed a male to 1/4male adaptor
It's a bits power T with a 45 off it.
The T is all female so needed the male to male to plug in to rad. You can get male T pieces but it made no odds. As for flow if you lessen the cap a touch you can bleed it up
Aaaaaah! I have noticed the connection now Having some blond moments... guess it's the weekend coming causing all this
