I know this is an old thread but im looking through for some inspiration and this build is just incredible
Just wondering what LED's are you using for the lighting? Would love some in my case, just got some SP120's and red braiding, inspired by this build mate
Wow - not seen that for a while.
It's the NZXT CB-LED10-WT 12x White LED Sleeve - 1m
Available at OCUK
Afraid not I sold the case last year. When you remove the original midshelf you drill out 4 rivets. I put M3 bolts through the holes and a nut, then rested the shelf on them.
Ahh thanks for that m8,
for some reason i was expecting a much more complicated solution
I found some perspex on ebay fairly cheap that they will cut to size,
where did you get yours from ?
