Hi everyone,
I know you guys get this asked a lot, but I need your suggestions for my rig as this is my first build! I will be buying the parts (base only) in about two weeks and would just like to hear some suggestions before I make my purchase
Budget: £780-£830
Main Uses: Gaming, some AutoCAD and 3D StudioMax rendering for my Civil Engineering course, and general internet browsing and watching films.
General Comments:
- SLi compatibility is a must for the motherboard (would like two cards in the future), as well as USB 3.0. I would also like the motherboard to be a Revision 3 model to save me swapping it in a few months.
- No need for a soundcard, on board will do me just fine.
- Don't really need an SSD either, but if it can bit fit in the budget, that would be a bonus.
- Would like to stick with Intel and Nvidia, always had very good experiences using their hardware.
- I will be gaming on a 1680x1050 resolution, but I imagine I will be upgrading later in the year for something bigger, so I need future proof hardware.
- I do have Windows 7 32 Bit already, but do you think that upgrading to 64bit will have major advantages?
- Do you suggest buying OEM for hard-drives, optical drives and processors?
Here is my current build (not including operating system - not in budget).
Gigabyte GeForce GTX 560Ti OC 1024MB GDDR5 PCI-Express Graphics Card ...£204.98
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM ...£169.99
Asus P8P67 PRO Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** ...£149.99
Coolermaster CM-690 II Advanced Dominator Case - Black Coolermaster CM-690 II Advanced Dominator Case - Black ...£72.98
Coolermaster GX 750W Power Supply Coolermaster GX 750W Power Supply ...£69.98
Samsung SH-B123L/BSBP 12x BluRay ROM DVDRW DL & RAM Lightscribe SATAII Optical Drive - OEM... £47.99
OCZ Special OPS 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3SOE1600LV4GK) ...£33.59
Western Digital Caviar Blue 500GB SATA-II 16MB Cache - OEM (WD5000AAKS) ...£32.99
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1155/ 1156 / 1366) ...£19.39
This comes to a grand total of £816 after shipping.
I could save some money with this bundle:
http://www.overclockers.co.uk/showproduct.php?prodid=BU-004-CM&groupid=701&catid=7&subcat=29
However, this is Coolermaster CM690-II Lite Dominator, not the Advanced, what do you suggest?
Sorry for all the questions, I just want to make sure I get everything right before making such a big investment (I am a poor student after all
Thanks for your help,
Kaz.
!Budget: £780-£830
General Comments:
) Thanks for your help,
Kaz.
