£800ish build
12 Dec 2005
So I've increased my budget for a gaming PC to £800ish
Only the system is needed. No OS. I think I'm settled on the H500 for a case
Will be for 1080p gaming. Do I go for a Vega or the 5700? Would appreciate some build suggestions
You have ~£200 for a GPU thereabout, probably worth getting a 2nd hand Vega 56 if you can. They are going for around £180 atm.
If you want a 5700 XT you're pushing the budget to ~£1000 region. Or ~£945 with a standard 5700 GPU.
Here's an initial spec idea to start you off (excluding GPU ofc)...
My basket at Overclockers UK:
Total: £612.90 (includes shipping: £0.00)
Thanks - I don't think I'm going to get anything better than that really am I?
Not really no for an £800 budget, it's pretty good going. You can't go any cheaper which would free up enough budget to get a better GPU.
GPU wise, I reckon a used Vega 56 will do you well anyway. If you feel the need then upgrade GPU again later when you have more dosh again. Although tbh the Vega 56 is a really good card still anyway.
