ok then cool, the only reason i was looking at the 1k unit is because it comes with the 4 PCI-E connectors for the GTX's but i can easy use the molex converters and save some money
I'd say you would be pushing it with a 520w, for a single 8800 card and a quad-core it would be fine but SLi plus all the rest means that it is very likely to be near its limits if not over them.
The Corsair 620W is a good choice but if you are after something a little cheaper then the Antec Truepower Trio 650W can be had for just £76 and is superb and the Akasa Ultra Quiet 650W for £82!
