- 8 Aug 2010
- Oxfordshire
https://www.youtube.com/watch?v=VoNRXWFTFa4
Thought it was interesting to see how well mirrorless is coming along.
Damn that man is annoying!
*a6300![]()
I have been eyeing up the 80d to replace my old 60d. Nice to know its a good upgrade
I don't understand why you'd have a 70D and a 80D at the same time.
I'd be tempted to sell both the 60 and 70d and get 2 80D's if APSC is your thing.
We probably have different 'needs' but if it was me. I would sell both and go full frame with a 5d3 or something.
Yeah full frame isn't for me
I don't do any portrait, people photography - I question getting rid of my 35mm sigma art 1.4
Very little landscape.. And not very good at it, but I do like water based shots
A bit of night time
But my favourite is nature, (Inc zoos) and macro
This includes birds in flight
There are times when a FF might be useful but I don't feel I can justify the cost when my main focus is geared towards APSC and they are cheaper
I'm not 100pc sure if crop is better for macro but does the extra reach you get with crop apply to magnification in macro?.. Downside.. Less light for those high shutter speeds
The advantage of a crop sensor for macro work is similar to distance work.
A 1:1 macro lens means an object that is 1cm big will cover 1cm of the sensor at minimum focus distance. If the sensor is bigger than that object will be covering much less of the frame, and you will have to crop down to get the same subject size. that is very similar to the problem when shooting distant objects on FF, you will have to crop down to get the same subject framing as a crop camera.
If the FF sensor had the same pixel density as a crop sensor then there is much less of an issue, because you can still get your APS-C crop. That is the only reason why I purchased a D800, wouldn't bother going FF if I got less than a 16MP APS-C crop.
With distant subject you can try and get closer or buy a longer lens. In reality both options have problem, sometimes it is physically impossible, dangerous or illegal to get closer. My 300mm f/4.0 PF weighs 700g, a 500mm f/4.0 weighs nearly 4000g and cost the same as a small car.
With Macro, you actually have even harder constraints. you can't get closer, because you are at the minimum focusing distance. Getting a long lens just means you can get the same photo being further away.
If you photograph object that are bigger than the 35mm FF then the FF sensor will be better but for smaller objects an APS-C camera has a big advantage.
Thanks dp
I already knew it for distance, but didn't think of the need to get closer for Macro
With my canon 100mm I already have to get all close its too close for insects
Also the Canon 180mm macro doesn't have IS
So really.. FF really isn't a good idea at all for me
I quite like him. Less entertaining but way more informative than digitalrev.
