80mm AIO?
17 Jun 2004
Eastbourne , East Sussex.
does 1 still exist? due to size constraints I cant fit anything larger
I know of the Coolit ECO C80 ALC , but that's from 4 years ago :(
I am pretty sure that the smallest are all 120mm rads these days. The Coolit's were absolute garbage and their customer support was easily the worst I have ever heard of. I have seen so many posts on many forums who had one of their awful products leak and wreck their pc's yet the company didn't care less. I don't like Corsair but at least they have a compensation scheme if one of their AIO's leak and break any other components.
Watercooling is in the end a method to bring heat to somwhere where you have more space for contact with air. If all you have space for is such a small radiator it will be very hard to beat a 92mm class air cooler that fits a lot of situations.
Magicool offer a dual 80mm and a single 92mm. You could use those with the Rajintek triton pump unit.
None of that is great value for money, and really only worth considering if all you have space for is a small low profile cooler as you don't need much of an air cooler to beat that.
If you have 125mm in height, I'd grab http://www.overclockers.co.uk/showproduct.php?prodid=HS-027-NC
