80mm fan for psu
8 Oct 2006
Im after a 80mm fan for a psu so no molex connection needed just 3pin and im not sure which ones will come without the molex.
Thanks.
Already have.
i did a RMA on my Enermax 850w to C&J Computers who do the RMA in the UK,and they sent me out a new PSU but it had a fan blade snapped,i got in touch with them and they wouldnt swap it they said i had to send it to Enermax German headquarters,ive done RMA to germany before and had to wait months so i thought it be quicker to replace fan.
it wasnt that hard taking it out as the 3 wires wasnt soldered but had a 3 pin connector on it.
Already have.
Not that its hard, its just dangerous.!
But if you want to do it, just go onto a well known auction site and type "3pin 80mm fan"
Simples
Simples
if they sent it you and the fan blade was snapped on arrival then it's law that they replace it as they gave you a item in return which was unfit for purpose.call them and tell them this. If they refuse then they are in the wrong how long have u owned the psu
Now that the OP has opened it, Thats all null & void.
