81c safe for n580 OC?
22 Apr 2011
Nottingham
As per title, 1.100V - 900/1800/2150
When gaming it will sit at 79-81c, Idle 35-40c.
I changed the fan profile to match Degrees c/% fan speed as such if that makes sense.. at 80c fan is at 80% give or take. Now it does get a bit loud but I dont mind if I'm gaming.
Are these temps within an acceptable range for longterm use?
If you plan to keep the card longer then yeah keep it under 80C (ideally below 70C). However I don't use such cards for more than a year typically so it's np for me to run them at 89C.
