- 16 Mar 2013
It's decision time again. I'm in need of a new CPU as I've just built a new work rig and put the 6350 I bought last year in that. Now I'm back to my 8150 Bulldozer for the time being.
I need some opinions from you kind folk.
It's obvious to see that the 9590 is currently the quickest CPU off the shelf from AMD and is the best buy when aiming for plus 5.0Ghz as an everyday clock. My 6350 has been doing this for the last 12 months.
However, I've read and seen opinions that the 8370E is actually the better chip to go for for plug 5.0Ghz overclocks.
My question is this. Is the 8370E a better piece of hardware? In that, is it made different, designed different etc to the 9590? What is making it appear to be better and warrant being advertised as happy above 5.0Ghz on liquid or top end air cooling?
As a caveat, I'd rather not here the just buy the 8350 chip, it's the same as the 9590 just clocked lower stock argument please. I had it with the 6350 and the 8150. My reasoning is that these chips are tested to be better at higher frequencies with zero effort and as such, are going to to go higher than buying one that's rated at a lower speed. The chance of getting one that's maxed out the box is the same, read tiny, as getting a lower rated chip that'll do astronomical clocks.
Look forward to hearing peoples thoughts on which chip I should buy next. And no, Intel is not an option. lol.
