Sweet, make sure you get some of the utilities.
Shows all my SATA 2 will degrade. Both SATA 3 ports connected are fine. If my other 2 SATA 3 ports get connected. It'll show up as fine also
Just updating my BIOS Now. Yeah ram will show as 1333mhz until bios update to 1.7 i think. Not sure if the XMS3 is rated at 1T, if so then yeah.
No problems.
Oh, btw. Did your Asus GTX480 come with far cry 2? Mine didn't and they've had to send one out. My starcraft 2 trial key also didn't work when trying to redeem... odd; just wondering if you've had this?
EDIT: 2T is fine
I just enabled OC Genie on my board (Yeah i know how to overclock, but im one of those lazy people who cannot be bothered) and oc genie has just clocked both my CPU and RAM up. Getting a nice 4.2ghz now
and thats just by pressing a button on my motherboard. I disabled all the green power and power saving crap in the BIOS so it doesnt idle at 1.6ghz when browsing the net. I prefer a stable 4.2ghz all the time. I really dislike to 'downgrading' when not using it technology.
Going to use MSI Afterburner to overclock my GPU (Heard its better than Asus Smartdoctor)
No problems.
Oh, btw. Did your Asus GTX480 come with far cry 2? Mine didn't and they've had to send one out. My starcraft 2 trial key also didn't work when trying to redeem... odd; just wondering if you've had this?EDIT: 2T is fine
and thats just by pressing a button on my motherboard. I disabled all the green power and power saving crap in the BIOS so it doesnt idle at 1.6ghz when browsing the net. I prefer a stable 4.2ghz all the time. I really dislike to 'downgrading' when not using it technology.Going to use MSI Afterburner to overclock my GPU (Heard its better than Asus Smartdoctor)
