8500gt appears!
28 Oct 2005
Scotland
JUst saw one and a price but just thought I would share the specs even although they are basic!
8500GT DDR2 Version
Memory Clock Speed:- 800Mhz
Core Clock Speed:- 450Mhz
Memory:- 256MB (DDR2)
DX Supported:- DX10
Monitor Connectivity:- 1 x DVI-I 1 x VGA (15 pin D-Sub)
TV/HD Output:- 1 x S-Video HDTV
Sounds like it does HD stuff so again could be another affordable option for a HTPC
Price, around £50
8500GT DDR3
Version
Memory Clock Speed:- 700Mhz(effectively 1400Mhz)
Memory:- 256MB(DDR3)
DX Supported:- DX10
Less than £70
Not too bad! For £50, it looks like a 7600GS performing can't with DX10 support. Not bad at all...
Mul
Mul
Yeha I thought that as well especially the DDR2 part sounds eerily similar to the 7600GS
Also seen this but more like 70 notes at the places I've seen it and it has a memory clock speed of 700MHz.
Infact good spot :) It comes in 2 flavours! DDR2 and 3
Faster mem = more expensive option!
DDR2 Sports 1600Mhz effective on Mem
DDR3 Sports 2100Mhz effective on Mem
Seen another for 58 +p+p now, the 8600gt's starts at 90 and goes all the way upto 195 for the GTS XXX version ouch!
Ummn, what you on?
700mhz = DDR/DDRII/DDRIII-1400
Infact, DDR > DDRII > DDRIII > DDRIIII because of timings in terms of speed.
An X1950XTX is not 4ghz mem speed due to G-DDR4 and my X1900XTX is not 2400mhz mem speed due to G-DDR3, whoever typed that is an idiot tbh :(
Mmm?
Sure that isn't 800mhz effective on the DDR2 and 1400mhz effective on the DDR3? :confused:
Mul
Its GDDR as in Graphics double data rate. The number 2, 3 etc indicates nanosecond speeds steps.
http://www.samsung.com/Products/Semiconductor/GraphicsMemory/index.htm
Say a 8800GTX has GDDR3 1.1ns = 900Mhz (1/time for frequency) or apparent double of 1800Mhz
GDDR4 0.714ns = 1400Mhz or double rate 2800MHz
Those cards are proberbly
GDDR3 1.429ns = 700Mhz or double rate 1400Mhz
GDDR2 2.5ns = 400Mhz or double rate 800Mhz
XFX are nuts. You can overclock any standard card for the same amount and save yourself £50.
