8600gt drivers control panel
30 Jul 2005
Midlands
on the 8600gt cards is there an option for the classic control panel or is everything now shifted to the new control panel only?
LoadsaMoney said:
Shifted to the new, will need a reg hack like the 8800's. :)
once reg hacked then the old control panel will appear?
reason i ask is i want to see if there advanced monitor setup is still available for these new cards, i will post a screenshot up in a little while from my 7600gs machine to show what i mean.
thats the screen i want to know if its still available with the 8 series of nvidia cards, the advanced timing screen. its available on the 93.71 latest driver for geforce 6/7 cards, and appears when coolbits is installed.
that screen basically does a better job than powerstrip for setting custom resolutions that show up in any game i use.
just making a 1360x768 rez is not good enough since i will need access to the advanced timing settinsg like the porch sizes etc.
Mav I just checked on my 7900gs options and it shows that advanced bit before enabling coolbits (enabled coolbits after).
<edit> with the 93.xx driver that is.
probably is available before coolbits, i forget now what turns up with coolbits other than the clocking tab.
so does anyone know if this shows up for 8 series cards?
i've just checked on an 8800 ultra and it appears to be there, or at least something very similar. you go > manage custom resolutions > create, and then open the advanced tab.
could you do a screenshot for us please?
