8700K 8Pack delid 5.0GHz AVX 0 rock solid. VCore too high?
23 Dec 2017
Bought this excellent CPU off 8pack 16 months ago and it's been rock solid at 5GHz with AVX offset of 0.
Was just running Prime 95 on it for a while and the temps are getting high - seeing a few Tj slow-downs on Prime95, although they are fine when gaming.
Setup is: (which number do I believe in BIOS - the one in the box or the one not in the box?)
Core ratios all 50
Speedstep disabled
CPU Core 1.328/Auto
DRAM Volts 1.408/1.4058
VCCIO 1.128/1.100
SA 1.128/1.100
CPU Standby 1.116/1.100
LLC Level 6
Current Cap 140%
Under Prime95 stress test HWiNFO64 is showing V-Core VID up to 1.448V and Vcore up to 1.504V. Seems very high. I assume the Vcore is being upped by the Auto setting from 1.328 to 1.504 when in use? Is this a bad thing? Does the Auto setting lack the control necessary?
Is it OK? Should I be changing something? Don't want to kill it prematurely.
Cheers,
I have that chip in the Maximus X, and run it 5GHz all core, AVX and cache/ring. I found that setting the voltage to adaptive+auto actually got me a better clock/volts than doing it manually. With manual volts I was only able to stay stable at 1.325v but when setting it to adaptive+auto I get a solid 5GHz all across the chip and voltage tends to hover between 1.28 and 1.3v. Try dropping your LLC down to 5 also, I've never needed more than that.
I'm not understanding something.
I set my VCore to 1.325 in the BOIS, fire up windows and HWinfo64 and it says the VCORE is at 1.472 without even running a stress test.
I am clocking at 5GHz AVX-3. LLC was 6 now 5.
Adaptive voltage, was auto before I started the current tweaks.
Why are my volts so high? Any ideas? What's the point of a Vcore setting in bios if it seems to get ignored?
Likely because you increased the current cap to 130/140% and if you've changed it to adaptive (auto?) then it'll pump whatever volts it thinks the chip needs. Just keep playing around with it.
So is it safe to reduce my CC?
Sorry, lots to learn :)
You shouldn't need to. What are your exact settings atm? You're not on the Maximus X Hero so I can't tell you exactly, but my settings are:
50x multi (all core)
AVX Offset 0
Cache 50
VCore mode: Offset (auto), which as I said actually allows me the same clock at lower volts. Quirk of the board I guess.
IO 1.2v
SA 1.22v
CPU Standby 1.2v
LLC 5
Current cap 140%
That runs flawlessly and idles around 26 to 27 degrees in my case, hitting 50-something under load.
OK Here is a list of my current setting. I notice on many there is a number beside the name with another number in a box which I can edit. I assume the number not in the box is the current value? Correct? So how does that relate to the numbers I enter in the box, which are not the same. Or have I got this all wrong?
Anyway, here are a bunch of my current settings - I have shown the settings in the boxes in [ ].
CPU Core Ratio: 50
AVX Offset: -3
Mem: XMP
LLC: 5
Current Cap: 140%
AC Load Line: Auto
DC Load Line: Auto
BCLK: Disabled
CPU Core Volts: 1.344 [Adaptive]
- Offset Sign: +
- Additional Turbo Volts: [1.325]
- Offset Voltage: [Auto]
DRAM Volts 1.408 [1.4058]
VCCIO: [1.1]
SA: [1.1]
PCH Core Volts: 1.032 [Auto]
CPU Standby Volts: 1.113 [1.1]
Can you explain why as I type, the Vcore setting above is 1.344V with Turbo Volts of 1.325, yet HWinfo64 is currently showing the very high 1.456V with the system not loaded at all?
Cheers.
After a long session of tweak and test I now have the machine running at 1.355V Vcore instead of 1.44V, and with AVX 0 instead of -3, and running cooler.
These are my settings. Can anyone suggest an improvement on this?
BCLK 100
AVX Offset: 0
SVID Behaviour: Best case scenario
CPU Core Ratio: 50 All Cores
CPU SVID Support Disabled
Mem: XMP
LLC: 5
Current Cap: 140%
AC Load Line: Auto
DC Load Line: Auto
CPU Core Volts: Adaptive
- Offset Sign: +
- Additional Turbo Volts: 1.355
- Offset Voltage: 0.001
DRAM Volts 1.4058
VCCIO: 1.1
SA: 1.1
