I have the PC in the sig, two systems in one case. the ryzen system is generally just idling when im using the intel. The temp is about 45 - 50 idle and high 80s to 90s on a CPUz stress test. Is this the expected temps for an overclocked i7. I have 2x incoming fans in front, 2x incoming bottom, 2x incoming side, 1x outgoing rear and 3x outgoing top on the AIO cooler. should i re-fit the AIO with some fresh Thermal paste.
