- 17 Feb 2010
- Newry
Hey,
Been a long time, but hoping some of you can help an Overclocking noob out.
Trying to help a friend with an issue. They have a Gigabyte H310M with 8700K.
They are currently having some issues with system stability, random power issues, restarts. I can see that stock is 3.7GHz. I opened the Gigabyte App Center> Easy Tune app, and I can see that it has a few options. The highlighted one is 'Default' with info below stating CPU (1 core) and a value of 4.7GHz.
Upon some investigating I see talk about MCE which could be enabled, causing this. If so, is that a Bios setting I can disable on the motherboard? I want to rule out any sort of auto overclocking if I can. Anyone have any experience with that Board / CPU, or MCE in general. Task Manager base speed is 3.7GHz - just not sure what values to trust and if the Auto overclock is activated somewhere causing problems? Haven't been able to get my hands on it to check BIOS myself (has been reset to default if I remember recently). Even at the bottom of the 'Easy Tune' app, there is a value which fluctuates between 3.4 and 4.5GHz if that helps - making me believe there is some sort of overclock on.
Thanks so much for any info!
