Hey guys, I am super newbie to this stuff literally started today! I have never OC'ed a CPU in my life, but with youtube everything is possible these days.
I have a I7 8700K, Gigabyte Z370 16RAM 3200 and watercooling, so my OC so far is:
Clock = 4.7
Vcore 1.20 (YUP that's right...)
C States disabled
XMP enabled to 3200
VCore Load = TURBO
So far the temp normal = 33C under stress 78C
Using the following benchmark tools:
Cinebench
Prime95
3DMarks
Monitoring using HMonitor
I didn't see much difference between 4.7 and 4.9 so decided to leave it at 4.7 to be on the safe side. My question is from all I've seen out there 1.20V for a 4.7 OC seems super low. Is this normal? Or should I bump it higher? Also, do I really need the C States disabled (if they are enabled I don't get as much performance).
Thanks in advance guys!
