8800 gtx help
10 Jul 2007
sheffield
hi i have this card but it seems 2 be stuck in 2d mode as my fps seem very low just ran rthdribl was getting over 400 fps now 127 fps been doing it a lot only way i can get it to go back right is reinstall drivers but its stated doing it more and more
OcUK GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - OEM
http://www.overclockers.co.uk/showproduct.php?prodid=GX-051-OK&groupid=701&catid=56&subcat=877
what can i dooooooooooo help
Manufacturer:asus p5b deluxe
Processor:intel e6600 @3.7ghz
Memory:GeIL 2GB PC6400C4 800MHz Ultra
Video Card:8800 gtx
Field Value
Sensor Properties
Sensor Type Winbond W83627DHG (ISA 290h)
GPU Sensor Type Analog Devices ADT7473 (NV-I2C 2Eh)
Motherboard Name Asus P5B Series
Chassis Intrusion Detected No
Temperatures
Motherboard 32 °C (90 °F)
CPU 42 °C (108 °F)
CPU #1 / Core #1 44 °C (111 °F)
CPU #1 / Core #2 41 °C (106 °F)
GPU 50 °C (122 °F)
GPU Diode 59 °C (138 °F)
GPU Memory 50 °C (122 °F)
GPU Ambient 41 °C (106 °F)
Maxtor 6V160E0 30 °C (86 °F)
Maxtor 6Y120L0 23 °C (73 °F)
Cooling Fans
CPU 1592 RPM
Chassis #2 4299 RPM
Chassis #3 1172 RPM
GPU 2930 RPM (100%)
Voltage Values
CPU Core 1.49 V
+3.3 V 3.26 V
+5 V 5.15 V
+12 V 12.20 V
+5 V Standby 4.97 V
GPU Vcc 3.25 V
Check that your PCI-Express slot is running at x16 and not x1.
There is a well known bug with your motherboard that sometimes glitches and slows the speed down.
yes its running at 16x . Its just a pain in the bum when itslows down max temp has never been over 65/68 c other than that is amazing card
well next time it does it i will just reinstalled driver again 3thd time this week
but if it does it again ill post here
was not able 2 do online one had the wrong one but im getting it now and will re run it
will run in 3dmark again with right version and post cpu screen shot as well
just glad its not my card lol evey thing in my comp is from here bar the case powersupply lol
if i could find a pro gor editng my motherboard bios i would find a way 2 sort it but ive not found eney pro yet that can do it
think i fix it just changed my nb voltage from 1.65 down to 1.5 i think and all back 2 norm woooooooooooooooooooooooooooooooooooooooooooow thanks guys for you help no 1 online shop and great forum thanks
this is the score i can get when all is well 3Dmark 2006 - 13440 marks
http://www.hwbot.org/result.do?resultId=623589
my name on ther is death on here and guru 3d is davido6
