So I have one of the early BFG 8800GT cards, the ones with the old (small) fan, and dislike the way it gets to about 88 degrees under load at stock speeds. I'm thinking about getting a heatsink for it, and was looking at the Thermalright HR-03-GT. A couple of questions:
How easy is it to fit on? Is it just a case of taking the case and fan off the GT and attaching it and the heatsinks?
How easy is it to get the case back on again, should the GT fail somewhere down the line? It voids the warranty doesn't it? Would this be a problem if I wanted to RMA it, or could I just put the case back on and no one would ever know?
Also, any other recommendations for heatsinks or ways to cool it are welcome. I'd probably look into attaching a 120mm fan to it, using cable ties. Is this practical?
Cheers all
Cheers all
