im running an 8800gt and just need clarification
i read somewhere that you can use the same chip card regardless of speeds
eg. a leadtek + BFG 8800gt would work together being the same chip regardless of the clock speeds
am i right in thinking this?
normally i have always gone for a powerful single card
but i had to go for the 8800gt on pricepoint as i needed a card on a budget
this was after moving from my old 7900gtx [as it burnt out - over enthusiastic overclock - my bad]
so really what im asking is
8800gt sli?
is it compatible using different manufacturers cards
will i see any benefit?
any other advice?
TIA
Rich
ps - have googled this before you all suggest
and would prefer a range of opinions from other enthusiasts
8800gt sli?
any other advice?
TIA
Rich
