I seem to be having all sorts of temperature problems with this new build
My BFG 8800GT OC was idling at 68, under load at 88. Decided to apply some AS5 instead of the crap they use.
With the AS5, the idle was now at 54. However, when under load, I'm hitting the 100 mark
I don't understand what's happened here, the fan is fully functioning (all of these temps with the fan at 40%). After playing CoD4 for about 10 minutes it's hit the 100 and now won't return below 60.
Should I try re-applying the AS5 again?
e: back down to the idle temp of 54, with my case fans on full.
I don't understand what's happened here, the fan is fully functioning (all of these temps with the fan at 40%). After playing CoD4 for about 10 minutes it's hit the 100 and now won't return below 60.Should I try re-applying the AS5 again?
