8800gts 640 temps
4 Dec 2002
ilkeston derbys
hi
ive just run furmark stability test with my card clocked to
620-core
1800- mem
1450- shaders
and its getting to 83 c after 20 mins . does that sound ok and is furmark pushing my card more than fallout 3
cheers
with mine in furmark it was maxing in the mid 70s, default oc. fan speed reaching 80%
id imagine as long as its stable, its fine :D
Mine with default oc, a bfg 8800gts 640mb, on 60% fan (which i dont think increases) is about 50c or lower idle and about 60c when running 3dmark06. Havent overclocked it anymore because i dont really need to.
hi
im using expert tool to overclock and the fan is on 100%
i read somewhere that furmark murders your g/card so i cant see it getting that hot in a game unless anyone knows better
cheers
Well of course 3dmark is going to tax the gpu, thats what it is meant for. So yeah it may give slightly un realistic results but as long as its below 100c and not showing artifacts or anything then its all good.
