8800GTS and Monitor Issues
7 Mar 2007
Kent
I've just recently built my new system, spec in sig but have a little problem.
My old system, with a nvidia FX5200 graphics card was able to connect to my monitor Acer AL1717, however, the connectors on my new 8800 GTS isnt the same.
Is there a cable that fits the 8800GTS and my monitor, or do I need a new monitor?
I'm assuming that your monitor uses a VGA (15-pin) cable. There should be adapters with your card that you can plug into the ports on the gfx card, converting them from DVI to VGA.
