Whats more important for new games; core clock or shaders?Not all GTS hit 2000 on the shaders and many bomb out at 1900 or below.
My GTS can hit 850 on core but only 1890 odd on shaders. If I drop the core to 830 I can get 1944 on shaders stable.
You'll actually find that the ASUS 8800GTS 512 is probably the best out of all the GTS's for overclocking (also might be why ocUK dont stock them anymore). I can get mine to 800/2000/2200 perfectly stable, but it begins to reach upwards of 60c idle, and 85-90c load, so I slow it down a little.Is it possible to overclock the asus version of this card - and by how uch and using what program (i.e easy overclocking )
Is that with stock fan speeds?You'll actually find that the ASUS 8800GTS 512 is probably the best out of all the GTS's for overclocking (also might be why ocUK dont stock them anymore). I can get mine to 800/2000/2200 perfectly stable, but it begins to reach upwards of 60c idle, and 85-90c load, so I slow it down a little.
It all depends on your system tempreature. Rivatuner is the best program to use for overclocking.
