8800gts and Source texture problem
3 Sep 2003
Staffordshire
Just got a new system built up and wanted to have a game of CS:S.
So naturally whacked settings on high, but it was awful, FPS dropped to 15 on Dust2.
After some tweaking I've found out that its something to do with the textures and AA. If I set texture detail to high and use anything above 4x MSAA, the FPS drops on some parts of the map to 15 then other is comfortable at 140.
If I set the texture detail to medium 8x MSAA is ok but above that it does the same.
Drivers are 158.22s
System is:
e6420 @ 3.2
P5B Deluxe
2GB Crucial Ballistix
BFG 8800GTS 320MB
Anyone else had similar problems?
Drivers are 158.22s
System is:
e6420 @ 3.2
P5B Deluxe
BFG 8800GTS 320MB
I had the exact same problem. I couldnt fix it. It would only happen on dust 2 though. I sold my 8800 and put my X1800XT back in as i only play css on my pc.
I've also noticed that in the 'System Information' panel of the Nvidia control panel the bus is listed as a PCI Express x1....anyone else get this?
Surely if it was running at x1 speed it wouldn't work at all.
couldnt you just turn AA off when you play dust2? Then wait for new drivers? sounds like something that could be fixed, i doubt the card cant handle the texture
100-190 depending on the level. It did drop to 80ish at one point.
But the second I turn High texture quality back on it goes down to 15-25
