8800GTS DVI - HDMI problem
1 May 2006
Bristol, UK
G'day guys.
Just finnished setting up my new build and have got my TV hooked up to my 8800GTS with a DVI - HDMI cable.
Problem is the resolutions are all screwy. I've set the TV output to 720p (max my tv supports) but when, for example, I set it as my primary monitor, it appears to crop the image by a sizable margin :confused:
Any suggestions?
Yes it's called overscan and it's perfectly normal for 720p over HDMI. Practically all tv's do this at 720p. So use vga instead to get 1:1 pixel mapping and native res. What tv is it?
