8800gts is dying, what to replace it with?
16 Nov 2009
inside your mind
Hi guys. My trusty card has has just started showing green lines across my screen
Can anyone advise me on a replacement?
Im using a q6600 at stock on a Asus motherboard of some sort...
Not sure how much to spend as its a old setup but has done me well. Looking to play watchdogs when it comes out.
Thanks for the help!
Hi guys i just got home, i looked at my psu and its a tagan 500W one not sure if its good or not but its been stable with 8 hard drives 8gb ram q6600 and the 880gts
Thanks guys
You'd want to change that if possible, something around 650W would be more than enough but it would give you a little head room. And you'll want a good brand, an XFX would do it.
I think the psu would be ok as Tagan are, iirc, a decent brand (age depending), though it certainly won't hurt to get a new one if you have the spare funds.
So i can get away with just the card? Happy days... saves me spending more money when i don't really need to...
Thanks again
