8800GTS Length (mm)
27 Dec 2006
Hampshire
Anyone know the average length of this card (mm). im Checking me case space and couldnt find anyone posting actually size or link to site stating size of reference or other 8800GTS card?
Also, am I right in saying it has only 1PCi-E connector and the GTX has two? Im running a Tagan 2Force 530W U22 PSU so am hoping this will do the job.
Alf
I've just replaced me X1900XT with an 8800GTS and I'd say the length is virtually identical, the clearance at the power connector end of the card appears to be the same as with me X1900XT. The card has 1 x 6pin power supply connector reqd to run it, and currently I'm using an enermax noisetaker 485w psu with it with no probs at all, BUT, I haven't tried to overclock it yet so this might have some bearing on performance. Hope this helps :)
If anyone needed to know the Dimensions for 8800 GTS are: 220mm x 100mm x 32mm (the last figure is the maximum thickness of a video card).
The dimensions for the 8800 GTX are: 270mm x 100mm x 32mm (the last figure is the maximum thickness of a video card).
